service engine soon light
Old 01-27-2012, 11:12 PM
turbotype87's Avatar
turbotype87 is on a distinguished road
Question service engine soon light
Hey all, I have a problem mwith my 2002 ZR2 Blazer. the service engine soon light won't shut off. I have tried to reset the computer by disconnecting the battery, that didn't work . I went to autozone to run the codes to find out what the problem was. the codes came back as a small evap leak and a bad cam sensor. So i replaced the sensor and cap and still have the same problem. Now i have a loud tapping noise when i start the car especially when its cold out. I DON'T KNOW WHAT ELSE TO DO? Any help would be appreciated.Is it possible that the emissions system needs to be checked out? thanks Scott
Old 01-28-2012, 07:24 AM
bigcountry58's Avatar
bigcountry58 is on a distinguished road
Everyone on here is going to ask for the specific codes, that is where you need to start...
Once you have the codes then there is a wealth of information using the search function with the pXXXX code you pull from a scan tool.
Old 01-28-2012, 08:09 AM
pettyfog's Avatar
What He Said!
And here's why...
That you say you replaced the cam sensor in such an offhand manner makes one wonder.. it's NOT JUST a matter of unbolting the old and bolting in new. Unless you really mean Crank Sensor.
The CAM sensor is what we used to call a Distributor. NOT a simple thing.
As to your knock when starting cold.. that's POSSIBLY a lube problem Could be a sticky lifter OR piston slap. It probably goes away as engine warms, right?
Question: Does it get LOUDER as you accelerate? Note I didnt say faster, said louder.
Old 01-28-2012, 10:54 AM
Rottidog's Avatar
The crank position sensor has very thin shims that have to be replaced & it is a very easy swap. I think it's a 10mm bolt holding it in. You wouldn't hear the CKP sensor tapping/getting hit more than twice in the position it's in. It would just get the sensor head broken off & the engine would probably die or run like crap.
2Blazers
03-07-2006 12:03 PM
amello1
01-02-2006 01:14 AM
alish199
09-29-2005 12:09 PM
TwilightEpitaph
08-11-2005 01:06 AM
gmyoyo
Engine & Internal
03-29-2005 12:17 PM
Quick Reply: service engine soon light
