Weird Overheating Issue.
Old 01-23-2013, 03:43 PM
xgiovannix12's Avatar
Default Weird Overheating Issue.
Hey guys My dads truck 97 s10 pickup 4.3 has a weird overheating issue.
The truck gets to 240 degrees. When I open the hood the top of the motor is warm. I could place my hand on top and would not even burn my self. I replaced the thermostat under warranty and it stopped doing it. Today it did it again.
Now I notice the top of the motor is warm and the heat does not work. Possible heater core being plugged? AN other bad thermostat?
Im at a loss. I would flush the heater core but its -12 and the outside water is turned off.
Im at a loss. Its possible the issue is right in front of my face but I dont see it. IM just really cold and tired.
Old 01-23-2013, 04:22 PM
jbb421's Avatar
jbb421 is on a distinguished road
my blazer did the same thing its a 96. flushed it refilled with antifreeze haven't had a problem since... ever since it did get to 240 the rad will only fill up about 3/4ths of the way no matter how many times i fill it it just settles there, but i cant see any leaks.
Flush it hope that fixes it. lol
Old 01-23-2013, 04:35 PM
sadly I wont be able to flush it till it gets warmer. But I do agree with flushing it.. I was on the same track.
Old 01-23-2013, 04:58 PM
Diaita's Avatar
Diaita will become famous soon enough
same problem on my 96. it would randomly over heat. Flushed it a few times and no problems since.
Old 01-23-2013, 11:29 PM
neo71665's Avatar
Dexcool?
When ya flush it make sure ya park it on an incline nose up to refill it.
Old 01-23-2013, 11:54 PM
jbb421's Avatar
Sheww my truck hasn't had dexcool in it for 200k when i got it the insides of the rad were so gunked up after 2 flushes, i just went and bought a new one and swapped to good ole green.
Hope the flush fixes it, Good luck!
Old 01-24-2013, 03:33 PM
Charles Hines's Avatar
Charles Hines is on a distinguished road
Drill a 1/8" hole in the thermostat plate.This will allow the air to purge in the system and result in a better regulation of the coolant temp.
rsangel
06-24-2015 08:50 AM
lost113
08-02-2011 10:11 PM
ontheplains
08-28-2010 08:19 PM
bobditts
01-31-2009 11:18 PM
gERgMan
09-06-2008 07:27 PM
Quick Reply: Weird Overheating Issue.
