What size are the front hub bolts?
Old 10-19-2010, 08:31 AM
Renthorin's Avatar
Renthorin is on a distinguished road
Default What size are the front hub bolts?
Specifically the 3 that hold the wheel hub to the spindle.
I think they are all 18mm but one was so rusty last time I had to use a 17mm to get it off. Would like to replace all three this weekend when I replace the hub (again).
anyone know the sizes? I assume any hardened bolt of the same size from the local hardware store will work?
Will
Old 10-19-2010, 06:38 PM
roycet4's Avatar
roycet4 is an unknown quantity at this point
Default been there, done that..
12x1.75 50mm long Hardened bolts. The originals are 18mm hex head, I too needed to use a 17mm to take off a few of mine. My dealer did not have the bolts in stock but I was able to buy the bolts at a local (very good) hardware store
Old 10-19-2010, 07:51 PM
chris99jimmy's Avatar
chris99jimmy is on a distinguished road
Will
How many miles are you getting on the new hubs? What kind are you using? What are you torquing the center 36mm hub nut to?
I am just curious because I just replaced a hub last year and it is getting noisy again after only 15k miles. I used Autozone, but I think I overtightened the center nut to 123 ft#s when I believe it should be just 103ft#s.
Cheers
Old 10-20-2010, 06:12 AM
Renthorin's Avatar
I don't remember the brand but it was from the local auto place. I tq'd the nut to 100 lbs. Found out later it should be 103 but doubt the 3lbs is what the problem is :-)
I have less than 1000 miles on the new hub.
Old 10-20-2010, 08:18 PM
Thanks for the info. Maybe someone will figure why hubs wear so quick. Anyway happy wrenching this weekend.
Melissa Cory Green-Veryser
06-07-2012 09:13 PM
r0k0
04-12-2012 09:28 AM
philipbolek
15
01-23-2012 07:08 AM
JasinP
01-26-2011 11:41 PM
Bberry20
09-21-2009 02:16 PM
Quick Reply: What size are the front hub bolts?
