What's this???
Vent tube and filter for the 4WD front axle actuator. The black plastic piece stuffed into the vacuum line, (in the first image) is the filter. Year, make, model and transfer case model will tell us where it goes.
NP236 is a 4 button, Auto 4WD, case. The vent/filter for the front axle actuator is incorporated into the vacuum switch on the firewall,
(sorry, figured you had the 3 button case). The line dangling under your vehicle is the vent for the transfer case. You can see where the fitting attaches in this image: http://www.midwesttrans.com/Np236_TCGM033.jpg
Probably didn't get put back in when they replaced the transmission.
