Where is the fuel pump oil pressure switch in a 1999 blazer - Blazer Forum - Chevy Blazer Forums
Reply
Thread Tools Search this Thread
Old 12-24-2009, 03:47 PM
sbrookover is on a distinguished road
Default Where is the fuel pump oil pressure switch in a 1999 blazer
Can anyone tell me where the oil pressure/ fuel pump switch in the 1999 blazer??
Old 12-24-2009, 03:57 PM
RonJon is an unknown quantity at this point
It doesn't have one. The pump will run 3 seconds when you turn the key on, run when it senses crank motion, run 3 seconds when you turn the key off.
Old 12-24-2009, 04:02 PM
thank you. Do you have any suggestion on my other question??
We have a 1999 blazer that has the fuel pump replaced 3 times in 4 months. the last time we beat on the tank and the truck started now it will not start. We have checked the replays, hot wired the pump and it ran but we have no voltage to the pump with the key on. Any suggestions?
Old 12-24-2009, 10:11 PM
windows_wizard is on a distinguished road
check out this pic see if it matches your engine.
http://i11.photobucket.com/albums/a1..._Locations.gif
Old 12-25-2009, 01:15 AM
terry s is on a distinguished road
Quote:
Are you sure? OReilly shows oil pressure switches for the gauge and also one for fuel pump switch & oil pressure. http://www.oreillyauto.com/site/c/se...zer&vi=1378997
Old 12-25-2009, 02:42 PM
And parts stores are known for being right! HAHA!!
RonJon is spot on. There is only one oil pressure sending unit (as shown in the image link above) and that does not directly tie into the fuel pump control system like the older models did.
Reply
Thread Thread Starter Forum Replies Last Post
1999 Chevy Blazer 4x4 Oil Pressure bryanbc Engine & Transmission 8 01-24-2013 11:18 PM
Oil Pressure Switch 1989 Blazer 2.8L gabhanjacisa Engine & Transmission 1 12-27-2010 01:18 PM
Fuel pump oil pressure switch robkolo1 Engine & Transmission 1 11-27-2009 10:40 PM
Oil pressure switch redundant fuel pump power? bmoehrke 2nd Gen S-series (1995-2005) Tech 2 08-07-2009 03:58 PM
How to check if oil pressure turned off power to my fuel pump willysboy2001 2nd Gen S-series (1995-2005) Tech 4 07-23-2009 10:21 AM
Tags
1999, 2000, 2001, 2003, 99, blazer, chevy, fuel, jimmy, location, oil, pressure, pump, switch, wre
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
