transfer case shift motor
Old 04-06-2008, 09:59 AM
walkingtall's Avatar
Banned
walkingtall is an unknown quantity at this point
Default transfer case shift motor
hello I have a 98 chevy blazer and want to replace the transfer case shift motor can anyone tell me how this is done, and if it is hard to do. thanks
Old 04-06-2008, 04:37 PM
Default RE: transfer case shift motor
The front driveshaft can make this a pain, but here is the procedure:
Removal Procedure [ol][*]Remove the transfer case shield. Refer to Shield Replacement.[*]Remove the transfer case wiring harness connectors from the motor/encoder.[*]Remove the bolts that secure the motor/encoder to the transfer case.[/ol]
The transfer case encoder motor is located on the driver side front portion of the transfer case.
Old 04-07-2008, 09:25 AM
Banned
thanks for the info, now do you have to move the drive shaft and if so what is involved in doing that.
Old 05-26-2008, 07:12 PM
Swiss is an unknown quantity at this point
Heya.. It was pretty simple to unbolt the T-Case motor from the T-case, you mentioned that the drive shaft would make it difficult. Does that mean you have to remove the drive shaft? I said there fiddling with the T-case motor trying to get it to wedge out some way or another and it just wouldn't fit.
I also had a couple other questions about the brake switch.
Flyfishen
06-18-2019 11:22 AM
PsychoGMRS
04-10-2019 07:08 PM
ChrisNick78
11-25-2012 08:09 PM
live4liftin
09-12-2010 09:39 PM
doodad69
11-29-2008 03:25 PM
Quick Reply: transfer case shift motor
