Will not shift into park
Old 10-14-2009, 08:30 PM
ffalan's Avatar
ffalan is an unknown quantity at this point
Default Will not shift into park
My 98 S-10 Blazer will not shift into park. There doesn't seem to be a visible problem with the gear selector on the column. There is no slipping in any of the gears, it just will not move completely into the Park position. The Park "light will not light up on the dash and the car will roll if left on an incline. Also, as you might have guessed, it will only crank in neutral.
Ideas?
Alan L
Old 10-14-2009, 08:34 PM
Shift linkage out of adjustment? Check out THIS POST for details on how to adjust the shift linkage.
Old 10-14-2009, 09:42 PM
blazerboyz's Avatar
Banned
blazerboyz is on a distinguished road
take a look under the truck on the driver side of the trans and see how the shift linkage is see if it came loose, you can tell by just putting your hand on it and give it a good wiggle, if not?! You and a buddy will be at this for a wile one in the truck the other underneith and you will have to adjust to what the underneith guy says, any who you will figure it out its not a big deal
Old 07-30-2010, 11:58 AM
DeWalt's Avatar
DeWalt is on a distinguished road
Ideas?
Alan L
Have the same problem with my '96. Followed the suggested steps to adjust the shifter linkage that was provided. It worked 3 instances of putting it into park but has since returned to not going into park again.
Old 08-01-2010, 10:49 AM
LannyL81's Avatar
LannyL81 is on a distinguished road
Question: using your hand are you able to shift the trans into park by pushing on the linkage at the trans? If so then it is the cable. It is out of adjustment because it has probably broken. This is a PITA to fix as the new cable runs under the carpet and through a grommet in the floor. Actually takes about two hours to replace...but what a PITA to do.
What happens is the clip that holds the adjustment is in a plastic body. The plastic body has broken so the entire cable moves instead of pushing or pulling the shift linkage.
Did I mention that this is a PITA to replace....
Mine broke one night for the wife...and after two weeks of putting trans in neutral, setting parking brake, crawling under to push linkeage into park...I had enough and replaced the cable.
Got mine from Rock Auto.
Good luck and oh....have fun.
derekhollister
06-05-2017 10:55 PM
myhotrod1968
07-31-2011 09:21 PM
toolman243
06-04-2010 05:29 PM
Hiddenfarce
05-25-2009 11:21 AM
Chakoose
03-27-2009 04:35 PM
Quick Reply: Will not shift into park
