window motor replacement
Okay, my driver's window no longer moves...theres' no noise, it just doesnt' move. I do have power at the switch. At idle, if i hold the switch in either direction i can see the voltmeter on the dash dip a little.
It's 100$ more to buy a motor with regulator but i've been reading and it seems it's harder to change a motor without changing the regulator because you have to remove the regulator anyways and then keep it from colapsing.
What's the best thing to do? Is this a really brutal job?
RE: window motor replacement
Turns out it was the motor. Swap was easier than I figured...just over an hour top to bottom. DcFlux's writeup is great especially for removing the door panels.
packmule75041
01-03-2010 04:02 AM
GHN111
10-03-2009 07:52 AM
Shaun98si
07-28-2009 08:09 PM
