1993 Full size blazer, radio won't fit?
Old 07-23-2013, 09:44 AM
TimberwolfFXDL's Avatar
TimberwolfFXDL is on a distinguished road
Default 1993 Full size blazer, radio won't fit?
Used a Metra dash kit (Gray, which doesn't come close to matching the factory gray btw) and a pioneer deck. I can't get it to go all the way in. It's stopping against something, but I can't tell what. There's a metal bracket/stiffener, but it doesn't look like it'd be in the way. The wiring is tucked nicely.
What else am I missing? Is it possible it hits something in the HVAC ducting?
I can't see or feel from underneath without pretty much pulling all the ductwork out of there...
help?
Old 07-23-2013, 10:03 AM
xgiovannix12's Avatar
My fullsize does the same thing. I never found a solution for it.
Old 07-23-2013, 01:04 PM
chevy fan302's Avatar
chevy fan302 is on a distinguished road
you able to get a pic down inside where the radio goes in? I have been doing audio for years I might be able to give some input to help you out
Old 07-23-2013, 05:36 PM
Horton's Avatar
Horton is on a distinguished road
Not a definite answer, but I have read that a lot of aftermarket H/U's will protrude an inch or two if you don't remove the support bracket behind the stock H/U.
Old 07-23-2013, 05:40 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
I had a problem like this with my first gen, the RCA cables were hitting the hvac duct behind the radio.
I am guessing that is what is causing the problem, or the old radio support like stated.
Old 08-02-2013, 11:26 PM
latic's Avatar
latic is on a distinguished road
Just done an install on a 95 and we had similar problems.
Behind the standard head unit on the lowerside is what looks like a duct, but is just used for cables (Grey plastic), above that is a fin to help hold the factory stereo in place.
We drilled holes into this grey plastic and then used cutters to get rid of the plastic. You'll also need to cut away plastic on the left corner that joins to the speedo casing and two ridges that go back to the bolt.
The aircon duct is at the top of the dash and shouldn't be messed with.
Old 08-03-2013, 07:38 AM
Pictures??
Old 08-03-2013, 02:45 PM
latic's Avatar
Unfortunately we didn't take pictures, however when I'm going to put the amp in and HD Radio I'll take some!
Old 08-04-2013, 07:28 PM
I removed the metal brace behind mine today. Radio sat nice and flush with the dash kit.
I never realized that it had a brace back there till I read it here.
admathi
12-15-2019 04:24 PM
USMCBlazer
07-13-2014 03:36 PM
icemanthe1
20
07-27-2012 05:37 AM
goerzenl
11-01-2010 10:14 PM
fullsize93
01-08-2009 01:19 PM
Quick Reply: 1993 Full size blazer, radio won't fit?
