Running Wires through Door Boot
Trying to install some components in 99 blazer 4 door. Have installed
the crossovers in the doors and want to use the stock tweeter locations
in the dash but cant get the speaker wire through the door boot on the driver
side. Has anyone done this? is it even possible? seems like mission impossible to me. Help!
thanks for the replies.
OK I'll have give it another try with a cable or something as suggested.
I'm not too crazy about having the x-overs in the doors either but
the only other place I can think of would be under the tweeters in the
dash and they would have to just lay there as there's nothing to screw them to.
Haven't done it in a long time, but yes, it is possible. I would, however, suggest not placing crossovers in doors where they can get wet and banged around when closing the doors.
Ok I gave it another shot after your inspiring replies and yep its doable. Pass
side isn't bad but driver side is a bit of a pain in the ***. The trick is to
put one finger in on the door boot side and fish another finger over
the emergency brake mounting plate and you'll find lots of room, you can't
see it but there is space. Taped the speaker wire to an extra long plastic tie
and fished her through. Put one x-over in pass side dash speaker(lots of room to
the left) and the other went behind the rear wiper switch. I used double
sided tape(Great Idea Guys) to mount them both. Thanks.
rogggg1020
09-24-2008 06:53 AM
cwiththehad
09-05-2007 01:14 PM
