Speaker Size
Speaker Size
First, thanks to this forum, its been a great help.
Next, my question.
What size is the speakers located in the door of my 97 S10 Blazer (2Dr, 4WD)?
Also what would be a viable reasonably priced replacement?
Next, my question.
RE: Speaker Size
6.5"
If it has the bose package its an 8" radiator
RE: Speaker Size
The bose is actually 7'
RE: Speaker Size
Well, My Blazer does not have a Bose setup, therefore what speakers do you guys recommend? Im willing to spend some decent cash, but nothing excessive.
Also a kind of related question, when I shut my Blazer off, the clock stays on the Delco Deck, how do I fix this? Its completely off, but the clock stays lit no matter what.
RE: Speaker Size
ORIGINAL: danmiranda
RE: Speaker Size
It doesn't play music, or do anything, the clock just stays lit. The ignition would be off, and the car would be totally off, no power to anything else, the radio's clock stays lit reguardless. Its driving me nuts, yesterday I had to jump her as the battery had died cause of it.
RE: Speaker Size
Sounds like your Ignition and Constant wires are mixed. Maybe the illumination wire is somehow getting power from a constant.
RE: Speaker Size
It could be a problem in the Deck itself. If you're replacing speakers, you might want to consider replacing the head unit as well. The factory deck is pretty weak on power output, and you could check the wiring while you have the deck out to see if there is something wired wrong, or if there is a circuit that is retaining power when it shouldn't.
c3478493
02-03-2014 02:56 PM
rick465
08-25-2006 09:37 PM
