Stereo Wiring and Install Parts
#161
i need some help. does the 2002 blazer ls 4dr have in dash speakers? its not the bose system but it looks like it has 4x6s or something in the dash i cant tell. i know for sure that it has rear and front door speakers im just unsure about the dash ones.
if it does have dash speakers, anyone know the wiring colors? because the wiring diagrams for everywhere i look seem to be LF RF LR RR but how is the in dash speakers wired?
#162
I think it might just be tweeters in the dash with bass blocker in a 4x6 adapter plate. Now for the speaker wire colors, I am guessing the same as the doors.
#163
The metra wiring harness for my 2002 came with a random loose red wire, about 16 inches long. It has a terminal on one end and the other side is just stripped. Any idea what this is for?
#164
Man GM went buck wild with factory sound system options. My 1996 4x4 LS came with AM/FM/Cassette (but not the one with the built-in 5-band EQ). Apparently there was a base level AM/FM radio, a mid-level AM/FM/Cassette and an optional AM/FM/CD. I'm guessing that if you purchased the AM/FM/CD option, you got the 4x6" tweeters or was that part of yet another option called "Premium Sound System". I don't know if any of the 1996ers came with 2 or 3-way speakers in the dash.
So anyway, I have the fiber-board blank outs in my 4x6 dash pockets and there is no factory wire connector present. So it looks like I'll have to provide the wiring myself if I want to drop something in there AND I DO! The factory door speaker were probably fine for AM/FM/Cassette which didn't put out much high range anyway, but with a new Pioneer FH-X700BT HedUnit I'm sure that there's plenty of high-freq sound that's just not being reproduced by the original door speakers.
I'm not finding 4x6" blankout plates for mounting tweeters. Maybe I'm using the wrong search term. I just don't have the metal working tools to make them myself and I'm not inclined to anyway.
I guess this is a good place to relate my experience with the HU install. The Original Equipment stereo was only 5-1/4 inches deep. One thing I hate with a passion is the way that most speaker listings don't include a depth spec. The time-honored DIN standard doesn't and never did include a depth spec. So I blissfully ordered the Dbl-DIN Pioneer FH-X700BT and the Metra 99-1045 dash adapter and picked up a GM wire harness and antenna adapter at Walmart and thought I was ready to rock. Of course the whole scene took a nasty dive when I discovered that the 6-1/2 " or so depth of the Pioneer was too much to fit. I wasn't ready to take NO for an answer so I went at it with my Dremel. I cut a bunch of plastic out of the dash innards which was super risky because a large bundle of wires happens to be fastened to the backside of that plastic. Anyway, this surgery did what I needed and now the Pioneer HU is installed and looks factory fresh in the Metra 99-1045 dash mounting adapter.
Word To The Wise
Try to find a stereo with less than 5-1/2" depth or go with a Single DIN HU. A single DIN will require considerable less plastic cutting and the Metra 99-1045 comes with a pocket to fill the lower DIN space on Single DIN installs.
Bear in mind that this probably only applies to '94-'97 Blazers. Perhaps later models are more accommodating for deep head-units.
Word To The Wise
#165
Just how many stereos DID GM put in the Blazers?
GM Regular Production Option (RPO)
Use this information to interpret the RPO numbers on the vehicles Service Parts
Identification (SPID) label (located in Glove Compartment?).
*****************SOUND SYSTEM RELATED ITEMS****************
B67 2482 P CONTAINER RADIO CASSETTE TAPES 840417 E E E A
T9F 25890 P RADIO EQUIPMENT FRAME MOUNT, STORAGE BOX 990223 E 5 E A
U56 27069 P ENP R ENTERTAINMENT PKG REAR SEAT, PLAYER, DVD, OVERHEAD UNIT 10122 E 0 E A
U57 27070 P SPR M SPEAKER SYSTEM 8, DUAL F/D PILLAR, DUAL FRT DR MTD, DUAL RR DR MTD, SUBWOOF PKG SHELF, I/P CTR, AMPLIF, BOSE 971008 E 4 E A
U59 27072 P SPR M SPEAKER SYSTEM 8, QUAD FRT DR MTD, QUAD SAIL PNL, AMPLIFIER 970312 E 1 E A
U61 27100 P SPR M SPEAKER SYSTEM 10, DELUXE 980512 E 5 E A
U62 27101 P SPR M SPEAKER SYSTEM 4, DUAL COAX FRT, DUAL COAX PKG SHELF 850318 E 4 E A
U63 27102 P SPR M SPEAKER SYSTEM 9, PREMIUM 980512 E 5 E A
U64 27103 P SPR M SPEAKER SYSTEM 4, DUAL FRT DASH MTD, DUAL STD RGE PKG SHELF/QTR 830101 E E E A
U65 27104 P SPR M SPEAKER SYSTEM 7, PREMIUM 991222 E 1 E A
U66 27105 P SPR M SPEAKER SYSTEM 7, CUSTOM 991112 E 4 E A
U67 27106 P SPR M SPEAKER SYSTEM 7, QUAD FRT DR MTD, DUAL RR DR MTD, SUBWOOF PKG SHELF, AMPLIFIER, BOSE 980619 E Z E A
U68 27107 P DISPLAY DRIVER INFO CENTER 840919 E E E A
*******************HEAD UNITS*********************
TD0 24759 P RDO M RADIO AM/FM STEREO, W/STD ANT & SPKR 951011 E 5 5 A
TD1 24760 P RDO M RADIO AM/FM STEREO, CASSETTE, MTR, W/STD ANT & SPKR 951011 E 5 5 A
TD2 24761 P RDO M RADIO AM/FM STEREO, CASSETTE, MTR, W/PWR ANT & SPKR 951011 E 5 5 A
TD4 24763 P RDO M RADIO AM/FM STEREO, AUTO-EJECT CASS, DIGITAL, MTR 980311 E 5 E A
TD7 24766 P RDO M RADIO AM/FM STEREO, CASSETTE, ETR, W/STD ANT & SPKR 951011 E 5 5 A
TD8 24767 P RDO M RADIO AM/FM STEREO, CASSETTE, ETR 951011 E 5 5 A
TF2 24833 P RDO M RADIO AM/FM STEREO, ETR W/MANUAL ANTENNA 980309 E 5 E A
TG0 24867 P RDO M RADIO AM/FM STEREO, SEEK, CASS, W/O DISPLAY, ETR 951011 E 5 5 A
TH8 24911 P RDO M RADIO AM/FM STEREO, DIGITAL, ETR, W/SPK & MAN ANT 951011 E 5 5 A
TH9 24912 P RDO M RADIO AM/FM STEREO, SEEK, AUTO REV CASS, ETR 980309 E 5 E A
TG1 24868 P PLAYER COMPACT DISC (BRAZIL) 980309 E 5 E A
2F0 36495 P RDO M RADIO INTEGRATED MOBILE TELEPHONE, MEC 990929 E 0 0 A
2F1 36496 P RDO M RADIO CAR100 971129 E 0 0 A
2F2 36497 P RDO M RADIO CAR300 UKW/MW/LW, RDS-E0N, FM-MEMORY, TA,CASSETTE (FF/FR) 971211 E 0 E A
2F3 36498 P RDO M RADIO CAR400 UKW/MW/LW, RDS-E0N, FM-MEMORY, TA, CASSETTE (FF/FR, DOLBY B, CASS PROGRAM SEARCH, BASS, TREBL 971211 E 0 E A
2F4 36499 P RDO M RADIO CAR500 UKW/MW/LW, RDS-E0N, FM-MEMORY, TA, CD, RANDPLAY, FF/FR, ELASPED TIME ON DISPLAY, BASS, TREBLE 971211 E 0 E A
2F5 36500 P RDS R SALES RADIO CAR2004 UKW/MW/LW, RDS-EON, FM-MEMORY, TA, CASSETTE (FF/FR) 981006 P 1 E A
2F6 36501 P RDS R SALES RADIO CDR2005 UKW/MW/LW, RDS-EON, FM-MEMORY, TA, CD, RAND PLAY, FF/FR ELASPED TIME ON DISPLAY,BASS,TREB 981006 P 1 E A
2F7 36502 P RDS R SALES RADIO CCR2006 UKW/MW/LW,RDS-EON,FM-MEMORY,TA,MULTIPLE CDRAND PLAY, FF/FR ELASPED TIME ON DISPLAY,BASS,TR 981006 P 1 E A
2G7 36538 P RDO M RADIO AM/FM STEREO, SEEK, AUTO REV CASS, SEARCH, ETR, PHONE, FADER, MEC 990929 E 0 0 A
2G8 36539 P RDO M RADIO AM/FM STEREO, SEEK, AUTO REV CASS, SEARCH, MULTI CD, ETR,PHO,FADER, MEC 990929 E 0 0 A
2G9 36540 P RDO M RADIO AM/FM STEREO, SEEK, AUTO REV CASS, SEARCH, MULTI CD, ETR, HPS, PHONE, FADER, MEC 990929 E 0 0 A
9R0 45999 C RDO M RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV CASS, CLOCK, ETR(SEO) 7 2 1 E T T A
9R2 46001 C RDO M RADIO AM/FM STEREO, SEEK/SCAN, CLOCK, ETR (SEO) 10213 E T T A
EGP 5416 P LOCAL RADIO/TAPE & CD SHUTTLE/CAR PHONE 6 SPK 20503 E S S A
U1A 26893 P RDO M RADIO AM/FM STEREO, SEEK, MULTI CD, ETR, NAVIGATION, FADER 990416 E 0 E A
U1B 26894 P RDO M RADIO AM STEREO-FM STEREO, SEEK/SCAN, COMPACT DISC, HPS,CLOCK, ETR 980619 E 4 E A
U1C 26895 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, CD, CLOCK, ETR 990330 E 4 E A
U1D 26896 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, CLOCK, ETR, NAVIGATION 20612 E M E A
U1E 26897 P RDO M RADIO AM STEREO/FM STEREO, SEEK/SCAN, COMPACT DISC, HPS, ETR 970422 E 6 E A
U1F 26898 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, COMPACT DISC, HPS, CLOCK, ETR 870909 E 1 E A
U1G 26899 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, CD, CLOCK, EQLZR, RDS, ETR, MP3 20207 E 1 E A
U1H 26900 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CD, CLOCK, EQLZR, RDS, ETR, MP3 20207 E 1 E A
U1J 26902 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, MULTI CD, ETR, HPS I/P, AUTO TONE, DSP 20903 E 8 E A
U1K 26903 P RDO M RADIO AM/FM/LW/SW STEREO, SEEK/SCAN, CD, RDS, DSP, SPD-VOL CNTL, ETR, NAVIGATION 971008 E 0 E A
U1L 26904 P RDO M RADIO AM STEREO/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CLOCK, ETR 970609 E 6 E A
U1M 26905 P RDO M RADIO AM/FM/LW/SW STEREO, SEEK/SCAN, CD, RDS, DSP, SPD-VOL CNTL, ETR, NAVIGATION, PHONE PROV 971008 E 0 E A
U1N 26906 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CLOCK, EQLZR, RDS, ETR 970609 E 4 E A
U1P 26908 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, CD, CLOCK, EQLZR, RDS, ETR 960229 E 4 E A
U1Q 26909 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CD, CLOCK, EQLZR, RDS, ETR 970609 E 4 E A
U1R 26910 P RDO M RADIO AM STEREO/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CD, CLOCK, ETR 891205 E 4 E A
U1S 26911 P PLAYER MULTIPLE COMPACT DISC 901213 E 4 E A
U1T 26912 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, CD, ETR, I/P, AUTO TONE 1103 E 8 E A
U1U 26913 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, MULTI CD, ETR, I/P, AUTO TONE 1103 E 8 E A
U1V 26914 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, MULTI CD, CLOCK, ETR, AUTO TONE 1103 E 8 E A
U1W 26915 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, CD, ETR, SECURITY FEATURE 980619 E 1 E A
U1X 26916 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, MULTI CD, CLOCK, ETR, HPS, AUTO TONE 1103 E 8 E A
U1Y 26917 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, MULTI CD, ETR, HPS, I/P, AUTO TONE 1103 E 8 E A
U1Z 26918 P PLAYER MULTIPLE COMPACT DISC, PASS COMPARTMENT 980623 E 4 E A
U3L 26976 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, CD, AUTO TONE, CLOCK, ETR, MP3 10105 E 1 E A
U3Q 26981 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, CD, DVD, NAV, CLOCK, DSP,W/VOICE REC MICRO 1114 E 4 E A
U3R 26982 P RDO M RADIO AM/FM STEREO, WX, SEEK/SCAN, CD, DVD, NAV, CLOCK, DSP, RDS, W/VOICE REC MICRO 1114 E 4 E A
U3S 26983 P RDO M RADIO AM/FM STEREO, LW, SEEK/SCAN, CD, DVD, NAV, CLOCK, DSP, RDS, W/VOICE REC MICRO 1114 E 4 E A
U3T 26984 P DLA R DISPLAY LANGUAGE TURKISH 990311 P 0 E A
U3U 26985 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, DVD, CD, CLOCK, ETR, NAVIGATION, VOICE REC, MP3 10109 E 1 E A
U3V 26986 P RDO M RADIO INTEGRATED MOBILE TELEPHONE, AEC 990322 E 0 E A
U3W 26987 P RDO M RADIO AM/FM STEREO, SEEK, AUTO REV CASS, SEARCH, ETR, PHONE, FADER, AEC 990322 E 0 E A
U3X 26988 P RDO M RADIO AM/FM STEREO, SEEK, AUTO REV CASS, SEARCH, MULTI CD, ETR, PHONE, FADER, AEC 990322 E 0 E A
U3Y 26989 P RDO M RADIO AM/FM STEREO, SEEK, AUTO REV CASS, SEARCH, MULTI CD, ETR, HPS, PHONE, FADER, AEC 990322 E 0 E A
U3Z 26990 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, DVD, CD, CLOCK, ETR, NAVIGATION, VOICE REC, MP3, VICS 10105 E 1 E A
U43 27030 P RDO M RADIO AM STEREO/FM STEREO, DSP, WX, HPS, RDS, PDA PORT, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CLOCK 990208 E 4 E A
U44 27031 P RDO M RADIO AM STEREO/FM STEREO, DSP, WX, RDS, PDA PORT, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CLOCK 990208 E 4 E A
U45 27032 P RDO M RADIO AM STEREO/FM STEREO, WX, RDS, CD, CDROM, NAVIGATION, CLOCK 990209 E 4 E A
U58 27071 P RDO M RADIO AM/FM STEREO, MTR 840425 E E E A
U60 27099 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV CASS, MULTI CD PROVISION, HPS, LED INDICATOR, REMOVABLE PNL, ETR 980921 E 5 E A
U69 27108 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, CD PLAYER, MULTI CD PROVISION, HPS, LED INDICATOR, REMOVABLE PNL, ETR 3 3 1 E 5 E A
#166
I have a 98 blazer ls didnt buy a wireing harness for my new stereo and was gonna connect wire to wire but i ran into a problem i only have one yellow wire inside my blazer and it says too hook it to a speaker but now when i start my blazer every morning i have to reset everything my clock my EQ what wire am i missing i have a dark green hooked to yellow orange to red black to black but i have a grey, another green and purple with white tracer that go to no place please help
#167
Try this link--->1998 Blazer Stereo Wiring
The constant 12V power wire in your vehicle is ORANGE, so you need to connect that to the 12V input wire on your new stereo. Your stereo may only have a single RED wire for that (depends on the unit). The YELLOW vehicle wire is "Switched 12V" so it only has power when the ignition key is turned ON or ACC.
Anyway the diagram at 12V dot com above shows what each wire in your vehicle does and your stereo should have come with it's own diagram so you can match everything up.
#168
Is there a mounting kit for a 1999 with a 'pocket' under the head unit?
Websites are saying GM1583B is for '92+ but the first post in this thread says GM1583B is '02+
#169
I have a 2002 and I bought a 70-20003/80-2003 and it doesn't fit. What is the deal? I need some help here, it's been very stressful.
#170
Help!!!
Want to upgrade your factory radio and/or your speakers? Here is all the info that you will need. You will need certain parts to install your new radio. The parts are: antenna adaptor only 1989 to 2005), a wiring harness, and a dash kit. The part numbers for these are as follows. *(M) stands for Metra Parts. If you have a 1st Generation S-10 (1982-1993)* you have 4x6 plates in the dash, and 4X10's in the side panels, or in the rear pillar. The wiring harness to add an aftermarket radio is 70-1677-1 (Metra) and GM01B (Scosche). The dash kit is 99-4544 (M), and Gm1500B (S) *Antenna adaptor is 40GM-10 (only for Years 1989-1993) If you have a 1st Generation S-10 Blazer (1982-1994)*, you have 4x6 plates in dash, and 6x9's in rear on side panel (4-doors will have 6 1/2's in rear doors instead of 6x9's) The wiring harness is 70-1677-1 (M) and GM01B (S) The dash kit is 99-4544(M) and GM1500B (S) *Antenna adaptor is 40GM-10 (only for Years 1989-1994) If you have a 2nd Generation S-10 (1994- 2003)* you have 4x6’s in the dash, 6 ½’s in the doors, and 4x6’s in the rear panel. Some models will not have an actual 4x6 in the dash, rather either a blank plate or a 1” tweeter in a 4x6 plate. The wiring harness for 1994-2001 is 70-1858 (M) and GM02B (S) The dash kit for 1994-1997 is 99-3043 / 99-3044 (M) and GM1515 (S) The dash kit for 1998-2001 is 99-3300 (M) and GM1588B (S) The wiring harness for 2002-2003 is 70-2003 (M) and GM05B (S) The dash kit for 2002-2003 is 99-2003 / 99-2001 / 99-3301 (M) and GM1583B (S) * Antenna adaptor is 40GM-10 (needed on all S-Series Trucks from 1994-up) If you have a 2nd Generation S-10 Blazer / Blazer (1995-2005)* you have 4x6’s in the dash, 6 ½’s in doors and 6x9’s in rear side panel. On 4-Door models, you have 6 ½’s in all 4 doors. The wiring harness for 1995-2001 is 70-1858 (M) and GMO2B (S) The dash kit for 1995-1997 is 99-3043 / 99-3044 (M) and GM1515 (S) The dash kit for 1998-2001 is 99-3300 (M) and GM1588B (S) The wiring harness for 2002-2005 is 70-2003 (M) and GM05B (S) The dash kit for 2002-2005 is 99-2003 / 99-2001 / 99-3301 (M) and GM1583B * Antenna adaptor is 40GM-10 (needed on all S-Series Trucks from 1994-up)
For Blazers and S-10s (including Bravada, Sonoma, Jimmy, Full-Size) the actual stereo wiring is as follows Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
For 2002 up blazers the wiring is as follows:
Radio 12v orange+radio harness
Radio Ground black-radio harness
Radio Ignition dk. green+radio harness
Radio Illumination gray (dimmer)+radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- tan - gray+,- radio harness
RF Speaker +/- lt. green - dk. green+,- radio harness
LR Speaker +/- brown - yellow+,- radio harness
RR Speaker +/- dk. blue - lt. blue+,- radio harness
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Power Antenna N/A
Very good decription but I would like to know this. I just hooked up a afterarket radio to my cousins truck tonight and it was playing through the speakers and then all of a sudden there was no sound and now cant get the sound to come back, what would cause this? And the radio still turns on and shows it is playing sound and isnt on mute so I am stumped.
