1999 Sandblazer Build
Old 06-15-2016, 08:36 PM
cdtek101's Avatar
cdtek101 is on a distinguished road
Default 1999 Sandblazer Build
Umm Sandblazer is the truck name, not sure I will be
doing sand dunes, but I live in the desert and thought
it sounded better then xxxxxxxxxxx..Lol
So I wanted to replace all parts that show wear or are worn already.
Then the fun stuff like light bars, lift kit etc...I will start soon.
Only a few pics so far since most work done under truck.
I put the Sandblazer badge on rear window
and the windshield logo will go on when the window
tint is done in a few weeks.
So far just under $ 2,000 between June 10 & June 15
-----Items DONE--------
Axel - Left Front
Brake fluid flush service
Brake Master Cylinder
Differential Flush
Fuel Injector service
Idler Arm
Inner Tie rods
Outer Tie rods
Pitman arm
Rear Pinion seal
Steam clean Suspension / Engine/ Trans ** Shop did Free **
Sway Bar Links ** Shop did Free **
Trans flush service
Trans Pan Gasket
Wheel alignment
Attached Thumbnails 1999 Sandblazer Build-windshield-decal-001.jpg   1999 Sandblazer Build-sandblazer-badge.jpg
Old 06-19-2016, 07:14 AM
cdtek101's Avatar
Started on the fun stuff, scheduled install of my Kenwood receiver, 4 Alpine speakers in the doors and my Pyle amp to be installed on Thursday.
I did manage to get the original untouched factory trailer wiring hooked into my LED Bow tie hitch cover today.
Old 06-24-2016, 02:59 AM
cdtek101's Avatar
6/23 -Today got the Sound system upgrade installed.
Old 06-24-2016, 06:09 AM
Tajohns34's Avatar
That is a nice looking head unit. I bet it sounds way better with that and the alpine speakers.
Old 06-24-2016, 12:56 PM
cdtek101's Avatar
Thanks and Yes very clear sound.
Old 06-24-2016, 08:10 PM
cdtek101's Avatar
Got the two front windows tinted to match rear ones,
and the front windshield limo dark strip done...also got my graphics installed...I have to re-take pics...sun was just too bright made the bright yellow come out darker on front and rear windows.
Old 07-02-2016, 08:34 AM
cdtek101's Avatar
Could not find a rocker panel housing or pod
for how I wanted it to mount so I made my own.
Attached Thumbnails 1999 Sandblazer Build-001_zpslznyng3d.jpg   1999 Sandblazer Build-002-003_zpsdwyildsf.jpg   1999 Sandblazer Build-004-007_zpscwywkpog.jpg   1999 Sandblazer Build-008_zpsnkvnmqkv.jpg
Old 07-04-2016, 05:24 AM
cdtek101's Avatar
Got the LED light bar mounted to the bull bar.
Figured out where to run the harness into the cab.
I am going through the antenna grommet, on passenger
side floor/firewall section inside the cab....just took
a very bright led light and a screw driver to figure
out where it came out on engine side fire wall...but I see
where now...Lol
It is close to exhaust pipe, so I am going to pick up
some type of insulation to wrap around harness for
that small section.
Old 07-09-2016, 09:49 AM
cdtek101's Avatar
Default July 9 2016
Got my Led Light Bar harness run from Battery to inside cab.
I ran it down along and under a/c housing to the antenna
access hole into the cab.
Installed my custom made rocker panel housing.
Got my rocker switches pre-wired and run taps off the Positive
and Negative new harness for rocker panel power, ..USB dual charge / Volt Meter LED rocker ..and the amp power off wire ready for it's rocker switch.
Attached Thumbnails 1999 Sandblazer Build-harness%2520001-002_zpsx82e9f3v.jpg   1999 Sandblazer Build-harness%2520003-004_zpszb4kxzc7.jpg   1999 Sandblazer Build-panel%2520001-2-3_zpsygztnwyi.jpg
Old 07-10-2016, 11:30 AM
cdtek101's Avatar
I got the rest of the rocker switches & light bar harness run.
All switches and lighting work and no disasters.
Attached Thumbnails 1999 Sandblazer Build-rocker%2520011-012_zpsyehaxjeg.jpg   1999 Sandblazer Build-int%2520lighting%2520001-002_zpso2tsgiub.jpg   1999 Sandblazer Build-light%2520bar%2520001-002_zpscuh6yqxi.jpg   1999 Sandblazer Build-light%2520bar%2520003-004_zpsf4b7p0le.jpg
Quick Reply: 1999 Sandblazer Build
