2000 Boring Blazer Build
Old 08-19-2014, 02:24 PM
Tajohns34's Avatar
Thanks! I am going to try to finish painting them this weekend and maybe just get some cheap used tires for now so that I can sell my camaro wheels. Then try to buy some new tires.
  #182
Old 08-28-2014, 01:14 PM
Tajohns34's Avatar
So this is how I decided to spend my weekend.
Here is a list of everything
Raybestos 445-1052 Professional Grade Steering Pitman Arm
ACDelco 45C1043 Idler Arm
Moog ES3462 Inner Tie Rods
MOOG ES3584 Outer Tie Rods
ACDelco 46A6004A Adjusting Sleeves
Raybestos 505-1104 Professional Grade lower Ball Joints
Raybestos 500-1057 Professional Grade upper Ball Joints
Moog K6530 sway bar bushings
DORMAN 722028 Spring schackles (which I didn't get to. I think I Might pay someone to do it)
I also replaced the power steering cooler lines with some bulk line that I picked up from Advance.
I got everything done and got it aligned. I also drained out as much dark brown power steering fluid as I could and refilled it. The steering feels way firmer and it doesn't knock going over bumps anymore, probably because all of my ball joints are now in 1 peice.
Old vs new pitman arm
My steering box. It is dirty and rusty but still works okay.
Also, I am hoping to get tires this weekend, but my schedule is so crazy for the next few weeks it may not happen.
Attached Thumbnails 2000 Boring Blazer Build-20140824_112300_zpshqytglq8.jpg   2000 Boring Blazer Build-20140824_112306_zpsgf6srs2m.jpg   2000 Boring Blazer Build-20140824_160535_zpsbqvwrol5.jpg   2000 Boring Blazer Build-20140824_155137_zpsprzcggf1.jpg
  #183
Old 08-28-2014, 01:16 PM
Tajohns34's Avatar
I forgot, I also got these on clearance from rock auto (about $12 a set). The fronts are at about 75% so they aren't getting replaced, but hopefully I can get the rears done this weekend because they are shot.
Attached Thumbnails 2000 Boring Blazer Build-20140826_144110_zps70cvp0hs.jpg   2000 Boring Blazer Build-20140826_144125_zpsbxcnieyf.jpg
  #184
Old 08-30-2014, 05:59 PM
Tajohns34's Avatar
So this happened today.
I am still trying to decide if I want to use the silver center caps or paint them black.
Attached Thumbnails 2000 Boring Blazer Build-20140830_152537_zps24ow3ri0.jpg   2000 Boring Blazer Build-20140830_184630_zpsmrespwtz.jpg
  #185
Old 08-30-2014, 06:37 PM
josh18657's Avatar
josh18657 is on a distinguished road
yes they look awesome with the black blazer
  #186
Old 08-31-2014, 07:13 AM
Tajohns34's Avatar
Thanks. They do look better than I expected.
  #187
Old 08-31-2014, 01:34 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
The shackles are gravy to swap out.
  #188
Old 09-01-2014, 07:49 AM
Tajohns34's Avatar
I have always heard that they are a nightmare.
  #189
Old 09-01-2014, 11:26 AM
rexmburns's Avatar
Super Moderator
rexmburns has a spectacular aura aboutrexmburns has a spectacular aura aboutrexmburns has a spectacular aura about
Mine took 30 minutes to do with no hassles at all!
  #190
Old 09-01-2014, 12:41 PM
newguy's Avatar
Mine took 2 hours. Cut off wheel to get the bolt out, drilled all the rubber out, then chisel the rusted sleeve out
Quick Reply: 2000 Boring Blazer Build
