98 jimmy poor guy slow build
all i did for power was to tap in to the factory wires for the factory fog lights so the same button powers both.
31's are doable on shackles and t-bar adjustment, you'll still end up with a little rub at full lock in parking lots though
also I ordered these on geek.com so long ago that I forgot about them two bucks per bulb the came in the mail from china today let's see how they do
driver side is the new led. i dont see much difference while driving, but the leds are definitely white not yellow.
I have HID low beams and LED high beams and it does help. It isn't so much the distance but the fact that the light is actually white.
im thinking about removing the front bumper cover to make the front end look higher but i cant seem to find any posts about it in the fourms after searching a bit. im wondering if i can take it off and trim the bottom half off and pit it back on since its the same color as the rest of the body. any info would be much appreciated
my buddy stopped by with his stock blazer
i also have the idler and pitman arms arriving today and a thrush welded muffler tomorrow
Now i know i have much beefier tires than your buddy's blazer but wow does your jimmy sit high. It also kind of looks like it might be a 2wd? Lift shackles are on my to do list. i think mine still has the original ones on it and they look like i could put my finger through the side of them. I'm just not looking forward to the hours of WD-40 and torching to get them off haha Your jimmy is looking pretty good though, keep it up!
