The Importance of Winter Wiper Blades and Glass Treatment
Snow, ice, freezing rain, and frigid temperatures make winter driving treacherous; nevertheless you're prepared, right? But what about your wiper blades? If they're the same ones that baked on your windshield all summer then you could be in for problems. How do you know if your wiper blades are any good? At no time of the year is seeing out of your windshield more important, and more difficult, than in winter. Quality wiper blades should evenly and effectively squeegee water out of their path in both directions no matter what speed you're going. Soft rubber compounds necessary for wiper performance are always under attack by road grit, the sun, acid rain, tree sap, ice, and especially winter salt. Arm your car or truck with Rain-X Glass Treatment and Rain-X wipers. Rain-X Latitude 8-In-1 Wiper Blades are the ultimate blades for sleet and snow. Unlike conventional wiper blade frames, the Latitude's beam design won't collect ice and snow, which can freeze conventional frames to the point where the blade no longer contacts the windshield. With Latitude blades you won't have to interrupt your trip to clear ice and snow from wiper blade frames, only to have them freeze again. You can check the presentation of this product here:
Another wiper blades Rain-X offers are Weatherbeater™ 22" Wiper Blade. Rain-X® - Chevy Blazer 2005 Weatherbeater Wiper Blade
Also Rain-X develops a line of related glass care products. Because Rain-X Glass Treatment requires the glass surface to be perfectly clean, Rain-X X-treme Clean is the perfect glass cleaner. It removes dirt, grime, and bugs, plus build-up that other cleaners leave behind, from glass and clear plastic. Rain-X 2-In-1 Glass Cleaner not only cleans, it also applies a rain repellent to improve wet weather driving. Click
to see how exactly it works!
Check an article on our website to learn more about these products: The Importance of Winter Wiper Blades
And are you ready for the winter?
Nope! The arm spring is tight. Its just not strong enough to overcome the built in curve of the blade. Any tighter and it would prolly be too much for the blade, windshield and arm to withstand. WTF is wrong with the blade?
The blade is the rainX recomended and about 2mo. old. It wont even clean the windshield washer fluid. The drivers bladeseems manufactured with too much curve. After all the windshield is nearly flat.
I have a 99 blazer and a 2000 ZR2, both vech. has problems with the pass side, wiper blades not touching midway the blades. the 99 has new blades and not the el cheapo ones,i have all but give up on them ever working right. i may replace the arm ans see if that helps.
