1998 blazer coolant temperature sensor
where oh where is the temp sensor at on my 1998 s10 blazer ? please help ?
You may have two of them. If you have two, there will be a 2 (or is it 3) wire sensor near the thermostat housing and a 1 wire sensor in the side of the driver side cylinder head. The one in the cylinder head is for the gauge and the other would be for the PCM. If you only have one, it will be in the driver side cylinder head.
1998 Blazre temp sensor
The Temp sensor on the drivers side of the block is the temp sendin unit, I know where thats at but Im havin a hard time locatin the male connector its supposed to go to. If I knew where to look for the connector I would know where to atleast try to locate it.
Carl@gmail
02-01-2015 03:20 PM
nick1269
08-08-2014 01:33 PM
