2000 Blazer
Old 05-29-2014, 05:11 AM
Xter's Avatar
Xter is on a distinguished road
Originally Posted by mattyboy1963
OK so the 2000 Blazer is a 4 wheel drive, can i still put my carburetored old school 350 in?
Yes just make sure the motor mounts are for 4WD.
Old 08-05-2014, 02:39 PM
mattyboy1963's Avatar
mattyboy1963 is on a distinguished road
I have an 02 Blazer 2 wheel drive that i am putting a sbc 350 carb motor. i was going to use the 460 tranny but was told that i cant cause its an eloctronic tranny and im not using the fuel injection, mass air flow ETC... Is this true? Also i was told that for 650 dollars i can get a controler that will permit it to work. Also was told the gauges would not work
Old 08-05-2014, 06:25 PM
Xter's Avatar
If you leave the ecm hooked up to just the transmission it should be ok. Hook your sensors up to the engine, I believe the sensors go to the ecm and then relay them to the gauges.
Now the only gauge you'll see problems with is the tachometer. Since you're carbed you're using a form of HEI or vacuum advance. You can check how the tach wires feed to the v6 disturbitor but I guarantee they won't be the same and even if they did, the tachometer wouldn't read the correct RPM. The best solution is an aftermarket tachometer you can mount on the dash and hook it up. Not stock looking but is the easiest.
jello219
09-03-2019 05:19 PM
01Blaze218
10-13-2011 10:05 AM
JODYM
02-02-2009 07:53 PM
lionel2
04-16-2008 04:45 PM
Quick Reply: 2000 Blazer
