2000 Blazer
Old 08-13-2014, 07:46 PM
sturmisch's Avatar
sturmisch is on a distinguished road
Default 2000 Blazer
Vehicle shut down at 75 mph coasted to side tried restart no power at all checked battery post broken off.Replaced battery but no firing only failed attempt to fire.Have fuel and pressure.No tach movement when engine turning over.Gave a shot of eiyther started in a violent idle that roughly idled truck for 10-15 seconds as what could be dieseling or mistiming.Thinking crank sensor but don't know or have had battery just disconnect on vehicle before.
Old 08-16-2014, 11:34 AM
burned's Avatar
burned is on a distinguished road
You need to do a more accurate fuel and leak down test.
If it was a crank sensor problem it would not start. Unless its hitting the reluctor then it would misfire and have a jumpy tach.
jello219
09-03-2019 05:19 PM
01Blaze218
10-13-2011 10:05 AM
JODYM
02-02-2009 07:53 PM
lionel2
04-16-2008 04:45 PM
Quick Reply: 2000 Blazer
