4.3L to 5.7L Vortec
RE: 4.3L to 5.7L Vortec
Sweet. Sounds like you have done some research.
I bought the JTR book from a guy I used to work with. I have the 14th Edition., Sixth printing 2001. I figured I would do a simple 4.3L V6 swap as my first engine swap. Then do a V8 Swap. Just not sure which truck I want to put it into. I might rebuild the 4.3L I pull out and stuff it into the '87, replacing the 2putt8. Then find a junk yard 5.7L and rebuild it and swap it into the '00. I will put a 2" body lift on the '00 before I drop the V8 in. That will help with firewall clearance, and tranny clearance.
Yea, removing the inner fenders is a snap, and propable a good idea.
i wonder how difficult a v8 swap would be into my 95? obviously alot different than the swap you are planning.
Hell yah swart that soulds like alot of fun. Make sure you post it all up so it will make my ls1 convetion easyier(in a yr or 2.)
Black 95 its easier than swarts will be. Just go to jtr.com and order the book, it will help out alot.
on 95's with CPI, you have to change the harness and computer over I believe, the V8's use MPFI.
Thanks cherry, I forgot about that.
Hey Kyle the ZR2 torsion bars are heavier and should work perfectly for this swap, yes they are 4.3Litres as well but the bars are definitely stronger. Make sure you get the complete Vehicle Identification Number from the engine donor truck to aid in the PCM programming.
hey swart will you have to get a new ECU or can u re-program you current one?
Thanks for the ZR2 info Bill!
And the PCM is the same for my truck as it is for the C/K pickups of the same year range (and quite a few other vehicles). Only difference is programming.
ORIGINAL: swartlkk
So basically its a direct swap? Is the PCM the same for mine (idk sorry) cause I've been thinking of this project for a long while now. just tryin tog et all the info i can
