Engine rattles after oil change
Valve noise on startup
I think Mav06 might be on to something...it could just be a lubrication issue at startup caused by an inefficient anti-drainback valve in the oil filter you are using. When you change oil, the new filter has no oil in it at first, so that's a good simulation of what a leaky anti-drainback valve in the oil filter would sound like. I described all this in greater detail in my post here:
https://blazerforum.com/forum/showth...ght=oil+filter
If that's the issue, then just changing to an oil filter with a good anti-drainback valve might cure it for you. Hope this helps.
MrBill99
MrBill99
I had the same problem on my 2000 4.3 blazer, put valvoline 10w-30 oil in it and solved problem.
nnaidas
05-07-2015 10:18 AM
Flatmatt
11-14-2014 08:35 AM
blazerbagpipes
12-13-2012 04:12 PM
