hard cold starting
Old 01-10-2010, 11:57 AM
builder125's Avatar
builder125 is on a distinguished road
Default hard cold starting
hey there im kinda new here i own a 2000 ls 4.3,and it takes 5 or 6 or7 tryes to start the truck in the morning,once the truck is warm and running it runs graet and starts great,its driving me nuts........help please!!!!!!
Old 07-31-2010, 12:56 AM
rocker's Avatar
rocker is on a distinguished road
same problem. seems like comp. not going into open loop for extra fuel
Old 08-24-2010, 07:00 AM
mike mtzr2's Avatar
mike mtzr2 is on a distinguished road
hi. what is comp and its function of open loop?
Old 08-24-2010, 06:40 PM
When the engine is cold, it runs in open loop which means that it is running more off of a predetermined set of variables instead of off actual sensor information. I wouldn't worry too much about that though as it likely doesn't have a thing to do with your problem. There would have to be A LOT of other problems with the PCM for that.
So lets start off with some general questions.
When was the last time a tune up was done (plugs, wires, cap, & rotor)?
Is the check engine light on and if so, what are the stored codes?
Have you done any other routine preventative maintenance (clean EGR, MAF, throttle body, and/or IAC valve - take a look in the Tech Article DIY Index link in my signature for how-to's on these)?
Shaneofcb
01-15-2011 11:16 AM
roadtrippers
06-04-2010 05:54 AM
boaterdude83
11-03-2008 11:09 AM
Mo Lee
10-15-2008 08:05 PM
davidmd
11-26-2006 12:47 AM
Quick Reply: hard cold starting
