How much cfm do I really need? - Blazer Forum - Chevy Blazer Forums
Reply
Thread Tools Search this Thread
Old 03-23-2016, 02:38 AM
error_401 is an unknown quantity at this point
Default How much cfm do I really need?
In the middle of rebuilding I'm stuck with some basics.
The heads of the 1994 blazers seem to suck at some 135 cfm.
When plugging in a couple of figures to try to get a hold of what cfm numbers are really required for a specific power output I'm getting to flows in the 75 - 85 cfm (theoretical) for a 250 - 275 hp 4.3l V6 (262 cid).
That would mean:
- the OEM heads would be perfectly fine to make that hp.
- at least half of the tuning for cfm on the heads is overkill.
I'm aware of the following:
- a high average airflow at half lift makes most power and especially torque
- the time is the restricting factor on a valvetrain but I'm aiming at around 3'000 - 3'250 rpm for peak torque
- even at 135 cfm below the opening curve of the valvetrain I should be able to get to an average of 75 cfm.
Is there somebody which can point me to the right sources of wisdom as to required cfm per cylinder?
Anybody ever tuned a 4.3l and what were the figures?
I guess that for serious hp I would need a head like BRODIX -6's or swap a 1996 or later kidney bean combustion chamber head on.
Reply
Thread Thread Starter Forum Replies Last Post
How much CFM is needed? (Radiator E-fan) Blade_24k 2nd Gen S-series (1995-2005) Tech 4 10-25-2013 04:26 AM
web site really really slow on certain posts serrasalmus The Lounge 3 06-12-2012 05:57 PM
CFM Technology IrvJr General Chat 4 05-07-2012 07:48 AM
To much oil+cold=really high oil pressure? Spectreblazer Full Size K5 Tech 3 03-15-2010 11:16 PM
How much work is it really to remove and install engine and tranny? 88s10Blazer 1st Gen S-series (1983-1994) Tech 7 11-29-2006 02:56 AM
Tags
cfm requirement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
