Timing Chain??? - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 12-12-2006, 10:58 AM
aris_unlimited is an unknown quantity at this point
Default Timing Chain???
How often do we need to change the timing chain. 2000 Blazer LT 4.3L 4X4 75500 miles
Old 12-12-2006, 11:40 AM
Default RE: Timing Chain???
When it breaks... The 4.3L is not an interference fit engine so a timing chain failure will not result in additional damage. Honestly, I wouldn't worry about it until well over twice the mileage you are currently showing if you did want to replace it as preventative maintenance.
Now if you had stiffer valve springs installed and/or higher ratio rocker arms installed, then this would create more stress on the chain and result in faster degredation, but the factory change setup is pretty strong.
Old 12-12-2006, 03:57 PM
thanks for the info kyle, like always you seem to know the answer to my question lol.
Old 12-15-2006, 03:18 AM
The best part.
He is usually right too.
Old 12-15-2006, 12:07 PM
Quote:
ORIGINAL: Hanr3
The best part.
Usually? LOL. Thanks Tim!
Old 12-15-2006, 01:19 PM
MNHawk is an unknown quantity at this point
If and when you do change this out, I would go with the DBL not the single. I upgraded this in my 350 when I rebuilt it and its still within .002 of new and 115,000 miles on it. (checked it when I replaced the timing cover gasket due to I changed out the cover).
On any car/truck/suv I get that has over 140,000 I change out the timing chain/belt just for peace of mind.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Timing chain cover replacement: do chain too? drblaze 2nd Gen S-series (1995-2005) Tech 18 06-22-2011 02:58 PM
timing chain cover??? black95blazer 2nd Gen S-series (1995-2005) Tech 5 01-30-2008 06:01 PM
Timing Chain Tensioner Burlisonm Engine & Transmission 1 12-29-2007 10:45 PM
timing belt or chain woodsballr 1st Gen S-series (1983-1994) Tech 4 02-20-2007 01:25 AM
Tranny and timing chain went out on old blazer 2001blazer General Tech Help 3 11-10-2006 01:48 AM
Tags
2000, 2004, 350, 43, 93, blazer, breaks, chain, changing, chevy, failure, gm, liter, milage, replace, s10, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
