What do you think of....
Old 02-28-2011, 05:31 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
Default What do you think of....
So I was looking at replacing my timing chain for a little preventative maintaince and while browsing through Napa's Website I found A Timing Gear set, not a Chain driven gear but a Gear drive Timing Upgrage... ( http://www.napaonline.com/Search/Det...+50014+2014003 )..So what do the people of blazerforum think? Is this a good upgrade from stock or a waste of money? do you think this would cause any problems? Lets hear your input!
Old 02-28-2011, 06:14 PM
TripleBlackBlazer's Avatar
Never seen them on a V6, always a V8. They sound crazy and I wouldn't mind one, but not sure how quickly it would get old.
V8 "gear drive blazer" search on Youtube
Old 02-28-2011, 06:47 PM
Yea, but those are straight cut gears with two idler gears like this ( http://www.google.com/imgres?imgurl=...:0&tx=87&ty=40 )( pete Jackson co. makes noisy and quiet ones but you cant use the ones with ilder gears on vehicles with knock sensors ) theese gerars are a hellicial cut so they should be very quiet, but is their a perfromace gain?
Old 02-28-2011, 08:01 PM
BlazinClinton's Avatar
BlazinClinton is on a distinguished road
we put a timing gear setup on our old ford shop truck at the last place i worked. that was like 3 or 4 years ago, its still in there! lol
i like them, but i would imagine that over time the teeth would wear and cause your timing to go out a little.
Old 02-28-2011, 08:40 PM
Yea, but i would imagine that even with wore gears it would still be more accurate then a streched chain? right?
Old 02-28-2011, 09:28 PM
Your knock sensor will go nuts with a gear drive. Lots more noise than a chain setup.
Wear is wear. So whether its a worn gear drive or a stretched chain, it will affect timing in much the same manner.
I wouldn't really worry too much about the chain in terms of preventative maintenance. Especially if you have no other reason to pull off the timing cover.
Old 02-28-2011, 10:18 PM
well I kinda do, I have a pan gasket and timing cover leaking oil, so I figured while im in there it wouldnt hurt to replace the timing componets. you think the knock sensor will still go nuts even with a matched set of hellicial gears?
BDS_237
04-19-2010 11:05 PM
butters
02-07-2009 10:59 AM
blazinon22s
09-17-2007 10:12 PM
LittleDan911
11-24-2005 02:45 PM
timetoblaze
09-25-2004 01:59 AM
Quick Reply: What do you think of....
