02 chevy blazer misfiring....help!
hello, I have a 2002 chevy blazer 4.3L 2wd with 230K miles. here is the problem: when i drive on the highway and i get to about 70mph or above, the vehicle will stop accelerating for a second and then go back to normal. at the same time the check engine light flashes. I got the code checked and they said it was a cylinder misfiring. It only happens when i get to 70mph or more. just a few weeks ago i had the wires, plugs, cap and rotor changed and it still does it. could this have anything to do with the catalytic convertor? I took it to car-x and they couldnt figure out why its happening, so i just had a radiator flush and new thermostat, and ball joints and brakes all the way around because it was needed. I just cant figure out why its misfiring. Ive been trying to do some research online to find the cause, but the only thing ive been told to do is change the wires, plugs, cap, and rotor, which i did. so if anyone has any ideas why this could be happening, please let me know. im willing to try anything. Thank you!
Question is who is going to do the diagnosis? If you want to do it we can help. If not you, then you will need to find a good shop. They don't come cheap... you will pay for their experience, expertise, and equipment.
peweepfp
03-25-2013 08:39 AM
jlow10
01-15-2011 03:10 PM
Magman
07-03-2010 05:26 PM
