1995 blazer back fire?
Old 06-04-2013, 08:47 PM
dbfishing's Avatar
dbfishing is on a distinguished road
Default 1995 blazer back fire?
I have a 1995 blazer runs fine when the whether is cool but when it worms up it randomly backfires and loss of power when accelerating bad blew the muffler apart bad I've replaced the egr, tps,map,fuel pressure reg,cap,rotor,plugs,plug wires,coil still no change no codes the motor is vin. w model been to two different shops they couldnt find anything wrong?
Old 06-04-2013, 10:36 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
check fuel pressure leak down, the lines to the spider (nut kit) can leak. Also the injector could go bad. Check ign timing, however I am unsure if it's adjustable on a 95. Double check firing order. If all else fails the only thing I could think of is the ign control module or it jumped timing
Old 06-05-2013, 09:40 PM
cferry7's Avatar
cferry7 is on a distinguished road
Default backfiring
I would suggest checking (1) timing (2) fuel - air ratio (3) exhaust system leaks. Running Lean and exhaust back into the cylinder's are primary causes for backfiring.
walleyehunter
01-09-2014 08:26 PM
IrMike209
05-18-2012 11:13 PM
tall_ish
11-20-2010 09:05 PM
BLaKZr2Bob
01-22-2010 07:46 PM
schnitzer00
04-12-2007 07:53 PM
Quick Reply: 1995 blazer back fire?
