1995 chevy blazer 4.3 missing real bad.
I have a 1995 chevy blazer 4.3 that is missing bad. No codes. Just changed the fuel pump. Direct pressure on pump is in the 60s but when hooked to the Schrader valve its like in the 59s and when running its in the hight 40s to low 50s. My guess is that's whats causing the misfire. but what would cause this other than fueal pump because it is new. Its not as bad when going highway speeds but its sucking down gas and has a little time accelerating unless I give the pedal a good press please anything to help would be great.
Unplug the MAP sensor see if it still does it, if so, get a new one. An MAP sensor is to the left of the spider injector plug and has three wires.
or the distributer, wires, and spark plugs
the cat or air filter
vacuum leaks
it goes on and on
vacuum leaks
it goes on and on
Mange98
14
02-24-2011 03:18 PM
