1997 blazer 4x4
1997 blazer 4x4
I have a 97 blazer other day I was driving heard no noises and lost all gears. I went out next morning started it up I had reverse, 1st gear, and 2 ND gear till it shifted into 3rd gear then I lost them all again. Any help would greatly be appreciated
check the transmission fluid also. a lot of those 9x blazers had problems with the radiator breaching between the transmission cooling and the engine cooling, causing darkening coolant and antifreeze mixing with the tranny fluid, which will cause failure when warm. I had that, and ended up replacing the tranny, the radiator, and going with an external tranny cooler instead of the combo
jasonv
11-22-2010 11:31 AM
jorg
08-22-2010 03:47 PM
devonlawrence
06-30-2009 09:36 AM
