1997 blazer running badly
Old 06-30-2014, 11:27 PM
djluomala's Avatar
djluomala is on a distinguished road
Default 1997 blazer running badly
So I got a 1997 blazer 4dr 4x4 just recently, it cranks for 4-5 seconds before starting, once it starts the whole vehicle shakes. The engine visibly shakes and idles @ 500rpm, it doesnt die just runs rough. Its running rich, can tell from the exhaust smell which leads me to believe that the spider, pressure regulator or injector(s) is leaking(will be getting fuel pressure checked Wednesday). I also noticed one of the spark plugs wires had a cut in it, when I unplugged the wire from the distributor there was no change in how the engine ran so that could be part of the issue as well( have new wires and plugs ordered). The check engine light will flash only @ idle. Soon as u put it in gear n start driving it goes off n stays off till u put it in park n let it idle for a minute or two. I've spent hours looking through these forums(which has been very helpful n got me this far) and has me believing that the issue is the spider injectors. Wednesday I'll be getting the oil changed, fuel pressure tested and codes pulled, is there any other things I should have checked while its in the shop? I also pulled the vacuum line from the rear of the intake and noticed the inside has black carbon build up in places then other places were golden looking as if it was washed with gas, I'll try to post pictures. The other issue I'm having is play in the steering, how can I pin point where the play is coming from and what ball joints are bad, or if the pitman arm is worn that badly?
Old 07-03-2014, 05:31 PM
Tenagator's Avatar
Tenagator is on a distinguished road
Sounds like it is the fuel injector assembly.
The pressure test will tell for sure.
I have a 95 and changed mine ....oh 5 times because I kept getting leaky ones.
As for the steering, I would get the front end off the ground , use jack stands!
And visually inspect all the steering components and see if there is any play by hand. Pitman arm, Idler arm steering damper bushings etc.
You may need a friend to help as well.
Old 07-03-2014, 10:07 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
what r the codes coming on? burning rich can be many things post the codes and for wires plugs rotor and cap use a/c Delco only, as these engines are particular
Old 07-30-2014, 09:11 PM
djluomala's Avatar
Ok so I been busy but I got my blazer running great now, I had 4 leaking poppets as well as my regulator.. don't even understand how the engine managed to run haha
lonebker
01-10-2010 11:04 AM
shamokin_blazer1977
02-24-2008 04:14 PM
Jrob11035
04-02-2007 09:54 PM
nhorn1983
01-31-2007 06:23 PM
jermoon
12-15-2006 08:45 PM
Quick Reply: 1997 blazer running badly
