1997 Blazer Trans Problem
Hello, I have a 1997 Cheve S 10 Blazer. I had trans problems so I bought a use one at a salvage yard. I was told that it had about 127,00 on it. It only had a 30 day warranty which has expired. What I have is when I travel with it a while, it shifts real hard into second gear. When it is cold, it works great. Has anyone got any imput on this ? Thank you.
I've been having problems with the transmission in my 98 S10 Blazer. I could almost write a book about my experience so far. I'll keep it short though. My transmission overheats and vaporizes transmission fluid. I originally thought it was coming out of the transmission vent tube but after removing the transmission and transfer case I found out that it's actually the transfer case breather. Anyway. I spoke to a transmission shop because I too had problems shifting from second to third when it was hot. I was informed that the 2-3 springs wear out in the transmission. That's just my two cents. I've tried the shift kits and it didn't make a difference. I'm in the process of installing a reman tranny. I'll let you know how it goes.
ksunday1
11-05-2013 02:22 AM
jasonv
11-22-2010 11:31 AM
