700r4 transmission problem!!
ive got a 91 s10 blazer with a 350 small block with an elderbrok tunnel ram with to holly 450s set up as a street/ drag truck but recently my trans has been screwin up ive checked tpb ( throttle position bracket) cuz i dont have the v6 anymore so no tps ( throttle position sensor) so im at a lost of whats goin on with it. i can take off from first but my rpms get up in 3 grand and wont shift untill i let off gas same with all gears and no od but p and n and r are fine just the normal gears and with slowin down it doesnt down shift at all i have to rachet into n to get it back into first. any ideas?!?
Just did same rebuild...well assisted with it anyway. We had same problem. For the OD problem we simply had to adjust the kickdown cable, ours was just a bit too long. I didn't work with the downshift issue but if I remember correctly he had to adjust the TV cable to fix that problem.
Diverknox
12-06-2009 11:48 PM
radje00
09-17-2008 12:32 AM
radje00
09-09-2008 10:49 PM
