1999 Blazer Transmission upshift issues after driving for a half hour
Hoping that with all of the knowledgable folks in this forum I can resolve this issue.
I have a 1999 Blazer 4.3 Automatic Trans. It was running fine and I have done a lot to it including trans fluid and filter. It developed a crack in the radiator tank so I replaced the radiator with a new one, after about a half hour of driving I noticed a issue with upshifting from a dead stop. It will shift if I wind it out to 2500 rpm and let up of the gas. Changed the Throttle Pos Sensor and harness. Still after driving about a half hour it has a problem with the upshift from a dead stop. It upshifts fine if I do it manually and there are no other shifting issues. When it is cold it shifts just fine.
The fluid smells fine and it is circulating through the radiator cooler.
I would greatly appreciate any help or suggestions I can get.
let me know what you find out. so far i have traced all wires going to transmission and transfer case also replaced speed sensors and changed complete valve bodys from a transmission that worked fine. I seriously have no clue why it is doing this. I have owned this blazer since 2012 and have only put about 400 miles on it.
matt4x4
01-11-2015 07:36 AM
sjmcarz
23
03-18-2012 03:34 PM
ddog800
14
02-16-2011 03:01 PM
TheNasty0ne
12-17-2010 09:59 PM
