2000 4.3L ZR2 Hesitating P0410 code* - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 06-15-2011, 03:10 PM
hellah fresh is on a distinguished road
Default 2000 4.3L ZR2 Hesitating P0410 code*
I have a ZR2 and it is hesitating after the engine warms up for about 2 mins. I did a scan and it showed code p0410 the Air injector so i gone ahead and replaced that and still doing the same thing. I searched another thread and the guy mention that he solved the same problem by replacing a stuck check valve? Here is the link to the original thread:
p0327 and p0410
My dad thinks it is the fuel pump but i dont want to throw anymore money that doent need to be throwing at i just want to solve the problem. Anyone have a clue?
Old 06-16-2011, 10:43 PM
AJBert's Avatar
AJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the rough
P0410 will have zero effect on how the engine runs. The secondary air injection system is there to soley warm the engine up quicker to get the cat up to temp quicker so it can stop those nasty toxic gases earlier from killing us all.
Old 06-17-2011, 10:51 AM
*FIXED*
Thanks for the reply AJBert. I have solved that problem and it turned out to be the fuel pump. I hooked the engine up the the fuel pressure gauge tester and the car psi was at 50psi. I revved up the motor an the gauge needle stayed at 50... didnt even climb up to 55psi so to everyone in the future just remember if all of your plugs and wires etc is ok.. a bad fuel pump will cause your car to hesitate. I changed out the fuel pump along with the fuel filter and BAM the car is back to normal.
Closed Thread
Thread Thread Starter Forum Replies Last Post
p0410 code lucas30 2nd Gen S-series (1995-2005) Tech 2 11-02-2011 07:50 AM
P0410 trouble code Klturi421 2nd Gen S-series (1995-2005) Tech 0 06-08-2011 11:25 PM
P0410 code and the check engine light robrote 2nd Gen S-series (1995-2005) Tech 6 03-11-2010 09:27 AM
code p0410 steve Engine & Transmission 1 11-04-2008 08:02 PM
Engine Code P0410? flyinbrad Engine & Internal 1 01-08-2007 12:40 PM
Tags
2000, 43, air, blazer, chevy, code, hesitation, injection, jimmy, liter, p0410, po410, pump, s10, secondary, slow, troubleshooting, zr2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
