2000 Blazer Transmission Problems
Sorry if this is a repeat post but I could really find anything with my specific symptoms.
2000 Blazer 4x4 with 125K miles and 6 months ago I had a leak around the transmission pan. I had it serviced. They replaced the fluid and filter and fixed the leak.
Now I have another leak but I'm not sure where it is coming from. Looks like it is near the dipstick tube. It has been doing it for about 2 months but it hasn't leaked more than a full quart in that time.
In the last 3-4 weeks it started surging while driving down the road while maintaining 45mph. It would stop when you let off the gas or accelerated. It did this before when it was leaking the first time but only when the fluid got low (over a quart low). Now it is doing it all the time when the fluid levels are normal.
Now it acts like it is not engaged when you try to accelerate from a stand still. When you press the gas it will slowly start rolling until it finally starts pulling normally. It started a few days ago only when it was cold. Now it does it when it is warm but only from a dead stand still.
The service engine light come on last week as well but I haven't had a chance to have the code checked.
Any ideas? Is my transmission going out you think?
TIA for your replies.
How many buttons on the 4WD dash switch, 3 or 4?
Have you removed the transfer case fill plug, (upper plug) and checked the fluid level?
With the engine at normal operating temp, and the vehicle on a level surface, check the transmission fluid level.
Post your results.
Post your results.
Post your results.
Post your results.
I don't even know where that is so the answer is no.
The fluid was about a quart low.( guess I shouldn't trust what others tell me)
I would like to add that the slow starts didn't happen every time you started from a stand still. Maybe it was from the fluid being low? Since topping it off I have not been able to duplicate the slow starts but I do still have the surging at 45mph.
One problem at a time
Low transmission fluid level will cause a hesitation from stops and erratic shifting. Both shifting into a gear, and shift points while driving will be affected. One quart low is substantial. Are there any external fluid leaks from the transmission? If not, it may have not been filled to the correct level the last time it was serviced, or, it may be leaking into the transfer case. On the rear of the transfer case there are two plugs:
Remove the fill plug, if fluid runs out, it's overfull. The excess fluid came from the transmission. The transmission and the NV233 transfer case use the same type of fluid, (Dexron VI). When transmission fluid migrates to the transfer case, the case must be removed to repair the problem.
Thanks for the info.
I had the oil changed last week and asked them to make sure they the transmission fluid was full but I guess they didn't.
There is an external leak and it looks like it is coming from or somewhere near the dipstick tube.
jello219
09-03-2019 05:19 PM
TessaBucklin
02-06-2013 07:56 PM
Duckman562
04-15-2009 06:15 PM
upblazer95
04-04-2009 08:27 PM
sfesenko
12-12-2008 10:03 AM
