4l60E slipping on 2nd and 3rd
Hi
I have 4x4 95 V6. I can drive it normally but when Im on 2 or 3rd gear it just slips , I can accelerate and overtake but if I push to hard it can go redline still accelerating. I need to be very carefull not to push it to hard on those gears
It drives fine on 4th -> lockup engages and I see no slipping there but it feels like it has no power, it likes to downshift (maybe it should work this way, my first car is srt so I cant compare). 1st and reverse works fine, will do burnouts.
Noticed that on park and idling after a while temp of the engine gows up..
I have changed solenoids A and B, no results. Changed the fuild and filter,no result. Only saw a bit of a sand in the pan.
Any advice?
Any advice?
ohh simple as that ok but could be there any malfunction in valve body to look for which caused plates to burn this way? Or cooling system which I have noticed isnt operating correctly could cause to fail the clutches?
95blazer8620
10-19-2007 01:26 PM
