4l60e trans just quit
Long story short burned up the trans in my 2001 Blazer had a 99 parts truck out back swapped out the trans. All said and done it was a little low on fluid, took it around the block and it ran and shifted beautifully. Next day topped off the fluid (overfilled it, maybe a quart and a half, oops) ran it through the gears and, moved it forward/backward a bit, seemed fine. Went to road test it and didn't make it out of the driveway. Felt a small jolt engine died. Started it back up and now I have no power in any gear. Checked fuses, all fine. Checked connectors on trans and tcase, all solid. No codes. Drained excess fluid no change. I'm so frustrated at this point I want to set fire to it. Any insight would be greatly appreciated as this is my only vehicle at the moment and I live 15 miles from work. Thank you in advance.
After some thought, what are the chances that maybe my torque converter self destructed?
atvwarrior
07-01-2013 05:14 PM
mitchiemitch422
10-02-2011 11:29 PM
Riktar
12-21-2010 11:20 AM
