4x4 help please!
#31
To OP. If you can use your EOBD Facile to communicate in a proper terminal mode, what you enter to check, interpret, and clear codes is at the end of this thread.
https://blazerforum.com/forum/2nd-ge...-blazer-89044/
#32
You're welcome, but I didn't write it - only collected it and used it when diagnosing mine.
#33
Encoder changed ... It was split apart on the top and bottom and cracked around the bottom bolt.. So anyone having similar issues with 4wd take a flashlight and look closely at the encoder motor. I never saw that it was split apart or cracked until I took it off . But on the positive side 4wd is up and running !! Woohoo ! Now that damn rattle is still there ..now in 4hi or 2 hi. Is there anything inside the passenger fender that could come loose ?
#34
#37
I've done fixed the hood .. It's not really a clunking ..the noise is hard to describe other than a rattle ..no difference over bumps,when turning or braking . It does it mostly between 35 and 45 and if I keep it there it stays..speed up or slow down ..gone. Everything in the front end is new and I took it for a ride after replacing each part .. no difference.. so it's really aggravating the heck out of me . At first I thought it was something that the wind coming through the engine compartment was making something rattle but that would get worse with speed I would think. Then I thought cat ..But It makes no noise sitting and revving the engine or when I tap the exhaust ..I'm sure I will find it eventually and think Duh.. lol but until then radio up and noise is gone ! Ha ha
#38
This forum and hands on with this beast have really taught me a lot about these trucks.. I've always been a 80's Monte Carlo person ( I could tear one them apart and put it back together with my eyes closed lol ) but I wanted a change of pace .. 8 of them was enough . Well for a while anyway.
opposedforces
09-01-2011 02:59 PM
mikejoann
01-04-2010 10:23 AM
