95 blazer 4.3 cranking more after driving awhile
I have a question i really could use some help on. I have starting issues on a 95 4.3 at first start up in the morning starts fine, after driving awhile it cranks more and more and you shouldnt have to but the more you drive you will need to actually need to press the gas to start. That said once started it runs great, it has new fuel pump (1yr ago) new fuel pressure reg, and fuel filter when pump was changed,. Just had a shop do pressure test and bleed down test both were fine. I have another parts 95, i swapped out the coil/mod on shops advice it did not make any difference. Runs great other than the starting issue.Sorry about the long read. Any help is greatly appreciated. Thanks
A1 Handyy
05-27-2014 04:40 AM
BL1TZKR13G
09-21-2012 03:34 AM
Big Ted
04-07-2012 07:01 PM
MXer746
06-06-2011 02:34 PM
