95 blazer manually switch to 2WH (stuck in 4WLow)
The transmission is bad. I need to get it to a shop to have it rebuilt, which will be approximately 40 to 50 miles away. It will drive forward (won't go into R or into N, so it can't be pulled backwards). The problem is, it is stuck in 4-wheel low and won't go into 2-wheel high. It is too far to drive in low, and If I put it on a trailer, I can't get it off without disconnecting the drive train again. Is there a way to manually get it out of 4-wheel low? Please help! Thank you!
hpblazer
03-22-2013 12:12 PM
jdwjohn
06-01-2011 09:04 PM
hill1
06-05-2010 01:40 AM
98BlazerLS
01-06-2005 10:37 PM
