oil pump low pressure
Old 10-15-2012, 07:41 AM
hellblazer's Avatar
hellblazer is an unknown quantity at this point
Default oil pump low pressure
i wanted to know f anybody knows why the am i getting low pressure reading ob my oil gauge.i just changed the oil sat.and this morning i noticed it being at 35psi.what is normal reading supposed to b.
Old 10-15-2012, 07:52 AM
Bdub's Avatar
Bdub is on a distinguished road
I think mine is 40 at idle fully warmed up
Old 10-15-2012, 08:01 AM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
I know the gauge is supposed to be almost at the middle while idling and when accelerating it goes up past the middle. Did you check the oil level?
Old 10-15-2012, 08:37 AM
newguy's Avatar
oil does get thinner when warm, which would show less pressure. What weight did you put in?
Old 10-15-2012, 09:10 AM
rriddle3's Avatar
Rule of thumb: 10 psi needed for each 1k RPM. GM specs 8psi minimum for our engines.
Old 10-18-2012, 05:39 PM
hellblazer's Avatar
i use 5w30 high mileage castrol gtx.i guess its normal.thanks eveyone.
Old 10-22-2012, 05:19 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default 40 psi @ idle after fully warmed is good.
My 4.3 in my truck starts up at 60psi.After it warms up it stays around 30psi at idle.I had a van with the same engine oil pressure was about the same till rod bearing started going bad.
musclecar70sfan
09-30-2010 06:58 AM
rohde782
10-08-2009 08:36 PM
Bigblue
10-01-2009 01:43 PM
noom14921992
11-09-2008 05:16 PM
s10_1997
03-28-2008 02:30 PM
Quick Reply: oil pump low pressure
