1994 S-10 Blazer miss
Old 12-17-2012, 01:33 AM
Torino's Avatar
Torino is on a distinguished road
Default 1994 S-10 Blazer miss
4.3 cpi. I have a skip on cyl. 4. It is constant at all speeds. Checked plug and was fouled with fuel. New plug still misses. Switched plug wires and still miss on 4. Cleaned disturber and rotor. Still misses. Compression 150. What do you think? I am leaning toward spider injector but not for sure.
Old 12-17-2012, 07:22 AM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
do a leak down/ fuel pressure test, procedure can be found with a simple search.
Old 12-17-2012, 05:03 PM
Twip's Avatar
i would agree...it could be a fuel pump. on my old 95 it was missing real bad on a few cylinders. after doing a full tune up- plugs, wires, cap and rotor- still had the same problem. took it to a mech and he checked the fuel pressure. it was too low at speed, but fine at idle. changed the fuel pump and it ran hard after that.
my next step would be to have the fuel pressure checked. its quick and easy. any mech worth his salt should do it for a few bucks if not for free.
Old 12-21-2012, 04:50 AM
Torino's Avatar
Did a leak down test and it held pressure. Guy at garage told me it was cylinder 4. Did a test and that cyl. has spark.
ussexplorer
09-27-2013 03:38 PM
onebadblackz28
08-16-2012 10:45 PM
Beckyj636
02-12-2009 07:09 AM
mikeswhls
08-03-2008 06:34 PM
mdish
10-31-2007 12:25 PM
Quick Reply: 1994 S-10 Blazer miss
