Frozen Transmission?
Old 02-29-2008, 11:38 PM
mccague36's Avatar
mccague36 is an unknown quantity at this point
Default Frozen Transmission?
I have a 98 with about 82k miles on it and after sitting out in the cold for some time, the transmission will not shift into reverse, neutral, drive, or 3 2 1. I have to let the engine warm up to nearly 200degrees before it will let me shift into gear. my guess is that there is some kind of water in the transmission that needs to melt before i can put it into gear. any suggestions or diagnostics would be great. thanks guys.
1998 4 dr 4wd 4.3L
Old 03-01-2008, 05:04 PM
Hanr3's Avatar
Default RE: Frozen Transmission?
Berify your tranny fluid is up to proper level.
Drive the truck for 20 minutes, park on flat level surface and leave the engine running, check fluid level on both sides of dipstick, twice. It only takes a pint to go from teh bottom of the cross hatch to the top on the dipstick tube. Top off as needed.
While your checking hte fluid level, what color is it, and what does it smell like?
If you have any foam or white stuff on the dip stick, time to get the fluid replaced.
Old 03-01-2008, 08:05 PM
mccague36's Avatar
thanks, ill do that
96blazersls
03-29-2009 06:22 PM
g4mbl3
01-01-2009 07:52 PM
mccague36
12-06-2008 09:38 PM
SmokeU
12-29-2007 09:44 AM
bat119
12-01-2006 04:39 PM
Quick Reply: Frozen Transmission?
