04-05-2010, 06:14 PM
99 blazer wont go over 60mph
my blazer started acting funny today while driving. it would shift fine at slower speeds and everything but once it got warmed up it wouldnt go over 50 mph. i know its not transmission. i was told it could be ignition coil truck will go to 60 then act like it is loosing power and will start dropping back in rpms and mph. what could it be please help.
04-05-2010, 06:46 PM
it sounds like your cat is finished.
if your truck is cold (like sitting over night cold), will it maintain highway speeds right away (while still "cold"), and hold them steady? and then once it has warmed up it gets really sluggish with no power?
drill a small hole right in front of your cat (3/8 is fine), and see how your truck drives then. you can also check what the temp of the cat is to see if it's plugged, but that isn't alway a sure fire way to tell.
as an example of that........the cat on my '98 was finished, but the temp was ok across it. when i pulled the cat, i found the front row of material had become clogged, then broke up into pieces, clogging against the second row, and was slowly choking off the exhaust.
__________________
'70 Dodge Dart 340 Swinger, 4spd, 3.91's, 383, 468 RWHP
'78 Chevy Silverado LWB, slammed (sold)
'79 Buick LeSabre 4dr, w/Olds 350 Rocket (1st ride)
'84 T10 Blazer w/8" of lift (sold)
'90 GMC Suburban SLE, a Canadian rust bucket (R.I.P.)
'90 Chevy Suburban Silverado, 6.2 diesel, a Southern Belle
'92 T15 Jimmy SLT, 4dr, 1 of only 2 factory 5spds. in Canada, and stupid fast (R.I.P.)
'95 Buick Regal LS, 290K, still going strong
'98 T10 Blazer LT, 4dr The Incredible Hulk
04-05-2010, 08:00 PM
i kjnow my converter was supose to be hollow out had trouble with it last year but i know there is a big converter before the muffler and like a smaller converter looking thing before that. yes it does maintain high way speeds after it sits all day but once it is warmed up it doesnt it will go to like 55 60 mph then wont go any farther
Tags
10, 2000, 50, 55, 60, 70, 96, blazer, chevy, doesnt, mph, past, truck, wont, wouldnt  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
