99 s-10 auto trans won't shift
Hi, I just bought this 99 trailblazer it was in a minor accident but had to replace oilpan and motor mounts. But now it doesn't shift out of first, unless I put it in second, then it stays in second. Also the speedometer doesn't work. Any help is greatly appreciated. Thanks
I would bet your two issues are tied together. The VSS sensor is used to control both the speedometer and shifting. It will be on the tail housing of the transmission (2wd) or transfer case (4wd).
Are there any codes present?
does anybody know where the wires go from the VSS?
To the PCM...
96jimmy4door
11-09-2011 08:14 PM
Tinted
35
02-07-2011 01:12 PM
Dennis The Menace
03-25-2009 08:41 AM
