Anyone used a sonnex smartshell on a tranny rebuild??
Has anyone used a sonnex smartshell on their tranny rebuild? I'm weighing my options for when I dive into this & for about $20 more than the Beast Sun Shell it seem like a good deal & it's lighter than the beast. I was going to go ahead & replace the one in it even if it's not messed up since it's a known weak point in the 4L60E.
2001 Blazer 2wd.
2001 Blazer 2wd.
I am not A big fan of the beast. In some builds I have had it rub the case. The only change that was made to the reaction shell was the removal of the 4 tab thrust washer between the front planet hub and shell. And replaced with a bearing. The Sonnax shell is great as it reduces the force that is put on the rear planet captured bearing by the sun gear and also the splines are heat hardened. There are several aftermarket companies offering a heat hardened shell that is just a durable in applications that do not over stress the gear train. In passenger cars,light SUV's I use a hardened shell. Any other build such as full size pick ups,high performance builds or any vehicle used for towing or plowing. If it is a standard application build I would suggest to spend extra money on other up grades as new boost valve, aluminium accumulator pistons,bushing kit.
Thanks for the tips about the boost valve, pistons & bushings.
CaptainK
07-27-2013 07:13 AM
Deathjester
Headers, Intake, & Exhaust
09-11-2009 08:37 AM
