Bad catalytic converter and bad bearing hub question!
Old 12-03-2007, 12:04 AM
yazan84's Avatar
yazan84 is an unknown quantity at this point
Default Bad catalytic converter and bad bearing hub question!
I've had a discussion last month about my car slowing down quick. In my last check up the mechanic told me that my catalytic converter needs to be replaced and my right front bearing hub sounds bad. My questions is do they effect on the car speed, and could that be the problem that I'm having with my car slowing down fast?
Old 12-03-2007, 12:57 PM
Default RE: Bad catalytic converter and bad bearing hub question!
A bad front wheel bearing could cause a drag on the drivetrain.
A bad catalytic converter would also limit acceleration so unless you are having problems with upper RPM performance, your cat is probably still OK. The only way to properly diagnose a catalytic converter is with a back pressure test where they would remove an O2 sensor before and after the catalytic converter and read the pressures. They should be pretty close together. If a large discrepancy is found, then the catalytic converter is bad.
Old 12-04-2007, 07:55 PM
Hanr3's Avatar
theres a self help thread on the hub replacement if oyu rinterested.
Old 03-10-2008, 06:53 PM
ZR 2's Avatar
ZR 2 is an unknown quantity at this point
Hey yazan, had the same problem occuring. When I was at crusing speds on the highway and took my foot off the gas pedal I noticed my truck would really slow down quicker then normal....now I have the constant drumming noise at highway speeds to contend with till I get it fixed
PaulO2288
08-06-2010 12:18 PM
soopahmario
03-15-2010 02:16 PM
matthew.chapman1
Headers, Intake, & Exhaust
10-26-2009 07:58 PM
Blazer4U
08-04-2008 05:12 AM
JEFFO2000
02-25-2008 07:24 AM
Quick Reply: Bad catalytic converter and bad bearing hub question!
