Belt tensioner pulley removal question
on the actaul black pulley that has the bearing in it, there is a bolt through the center that holds it on, which way do you turn the bolt to remove it? is it reverse tread or standard tread?
I am not sure on this, good question, as I know on the first gen you go to the left to take tension off the belt to remove it, and i was putting quite a bit of pressure on that bolt to keep tension off the belt and it did not break free,
are you 100 percent sure? i can't afford to damage anything so thats why i want to be sure. 3 guys on the other s10 forum said its standard tread but it can't be. just like the guy wrote above , i was putting quite a bit of pressure on that bolt to keep tension off the belt and it did not break free... Chris, if you have done this before, please let me know?
The bolt is reverse threaded. I just removed the black pulley (the one with the bearing) on my 1995 S10. Turn the bolt clockwise to remove, counter clockwise to tighten.
