Bolting the 4.3L V6 to the 4L60E
Old 04-01-2013, 06:29 PM
Johnny Mac's Avatar
Johnny Mac is on a distinguished road
Default Bolting the 4.3L V6 to the 4L60E
Greetings!
I just signed up and I probably have a really easy question. I have purchased a 4.3L V6 and 4L60E combo out of a wrecked 2004 Blazer. I am putting the combo into a 56 ****** wagon. Once the transmission is bolted to the rear of the engine how do you bolt the torque converter to the flywheel? I see a small access port in the bottom area of the trans housing. That will allow me to get two wrenches up in there? And I'm assuming there is a torque value? And how do you get a torque wrench up in there? OK four questions....
Oh wait, 5. What are your general impressions about the 2004 engine/tranny combo? This was out of a 2WD Blazer and I am converting the ****** to 2WD.
Whoops, 6. Do you guys know of any vendor that sells decent wiring harnesses with purpose built ECM's?
Thanks a lot for your input!
Cheers!
Johnny Mac
Old 04-01-2013, 07:28 PM
tttlesabre's Avatar
tttlesabre is on a distinguished road
Access convertor bolts through the location where the starter is. If you got the original harness and pcm with the engine you can send to Jims performance in Maryland and he will wire it as stand alone. He can also program pcm for you. cheaper then getting new harness.
Old 04-04-2013, 01:03 PM
abig84's Avatar
Yea through the starter hole. If you have a long extension, swivel, and impact its pretty easy
dj00140
22
11-04-2015 05:03 AM
an240172
09-07-2009 02:58 AM
95blazer8620
10-19-2007 01:26 PM
XBlazer01
06-04-2006 01:23 AM
02 Vortech
Engine & Internal
06-29-2005 06:12 AM
Quick Reply: Bolting the 4.3L V6 to the 4L60E
