camshaft position sensor p0300
code p0300 misfire... maybe I will replace camshaftsensor. I saw it the other day when i replaced cap and rotor. I guess i loosen that bolt to raise up whatever andreplacce sensor ? right? just dont turn anything!! I changed plugs cap and rotor so maybe I should have done sensor while there but then I would have never known then. maybe now I will learn something to help out someone else !!starts good but runs really rough. By the way just purchase code reader forall vehicles
RE: camshaft position sensor p0300
Why would a P0300 random misfire code lead you to a faulty camshaft position sensor? Is there a specific code pointing at the CMP sensor? You don't just replace the CMP sensor unless you have specific information pointing towards it being a problem.
Did you replace the plug wires? Blazerboy30 had the same prob and found it to be a loose #3 plug connection!
ok now I have replaced cap.rotor,plugs, wires and egr valve still have problem. still multiple misfires. should i check coil and oxy sensors?
Yep...but now my SES light came on. Got it scanned and still has the random/multiple misfire code? My blazers running great now..no miss or anything. I still have the high RPM"S though!![:@]
I don't know why I didn't catch this sooner, but I'm cleaning this up now.
Everyone wishing to respond to the OP, please do so in the following thread: crankshaft position sensor
Other threads to be closed and pointing to the thread above include:
IS IT TRUE?
camshaft position sensor P0300
shaking!!
IS IT TRUE?
shaking!!
russ1609
01-30-2012 07:08 PM
88blackzcand95blazer
01-26-2007 04:36 PM
